查看: 58|回复: 6
What is this warning sign with 65 in it means
 楼主| 发表于 2023-5-15 10:57:26 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1389.0,\"name\":\"\",\"url\":\"\",\"width\":642.0}]","canComment":true,"externalShare":false}
发表于 2023-6-6 12:17:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just drive driver.","replyToPid":0}
回复 支持 4 反对 2
发表于 2023-6-6 06:36:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"length restriction.","replyToPid":0}
发表于 2023-6-4 23:28:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is a stumper.  I’ve googled it and can’t find anything with a (65’) symbol on it.  Notice the single upper apostrophe mark which typically indicates feet.   What area / state is this in? ","replyToPid":0}
发表于 2023-6-15 03:54:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"From my understanding it tells you the distance from that sign - at that particular point, till the end of the segmented white line. ","replyToPid":0}
发表于 2023-7-20 07:29:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"white is length yellow is weight some yellow is height also","replyToPid":0}
发表于 2023-10-20 04:30:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I thought it was speed limit","replyToPid":0}
GMT+8, 2026-4-15 15:32 , Processed in 0.301414 second(s), 24 queries .
