查看: 92|回复: 34
Quick question
 楼主| 发表于 2023-5-15 08:46:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"How far can I make it with 1/4 tank of gas?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-5-16 11:15:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"lot of variables.  mpg avg 6 to 8. size of tanks.   loaded or empty.  terrain and traffic.   i would say blindly 250 miles and  get fueled up rather than find out at empty on the road.","replyToPid":0}
发表于 2023-5-16 04:57:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"1/4 as far as you can with a full tank. 🤷🏼‍♂️🤷🏼‍♂️🤷🏼‍♂️","replyToPid":0}
发表于 2023-5-15 10:11:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Until it’s empty ","replyToPid":0}
发表于 2023-5-16 10:14:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on your fuel mileage.\n\nKeep in mind if the fuel gauge is reading 1/4 it does NOT mean you have 1/4 of you total fuel capacity left.\n\nSince a semi's fuel tanks are shaped like a trash can lying on its side, the gauge is only accurate at full, half and empty.\n\nAt 1/4th its 1/4 of the HEIGHT of a full tank. That's more like 1/8th(ish) your total fuel capacity.","replyToPid":0}
发表于 2023-5-16 05:34:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Until you run out ","replyToPid":0}
发表于 2023-5-24 11:45:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"I never let my fuel gauge get down to a 1/4, that's making your fuel pump work harder","replyToPid":0}
发表于 2023-5-17 22:53:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"My truck only takes diesel. Don’t run on gas. ","replyToPid":0}
发表于 2023-5-17 20:28:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"do not think anywhere.\nthese trucks run on diesel.","replyToPid":0}
发表于 2023-5-16 23:01:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t make it a habit of riding with a 1/4 tank very often, it just shortens the life of your fuel pump. Once you get near 1/4 tank look to fuel sooner than later.","replyToPid":0}
发表于 2023-5-16 03:02:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Until the next fuel stop","replyToPid":0}
发表于 2023-5-15 09:04:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"It depends on?,?,?,?,?,?,?,?,?,.","replyToPid":0}
 楼主| 发表于 2023-5-15 09:21:24 来自手机 | 显示全部楼层
1009563 发表于 2023-05-15 01:04:12 It depends on?,?,?,?,?,?,?,?,?,.
","text":"On? ","replyToPid":474491}
发表于 2023-5-16 09:17:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve driven about 3 hrs on a quarter tank before I fueled.","replyToPid":0}
GMT+8, 2026-2-6 00:12 , Processed in 0.155338 second(s), 24 queries .
