查看: 145|回复: 11
speed limit alarm
 楼主| 发表于 2023-5-15 08:03:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"does anyone know how to turn off that over the speed limit Ding alarm ??? that annoying bell you hear when you go over the speed limit.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-5-16 05:35:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put a screwdriver tru the speaker ","replyToPid":0}
回复 支持 6 反对 0
发表于 2023-5-15 08:19:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"slow down","replyToPid":0}
回复 支持 4 反对 2
发表于 2023-5-18 07:49:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Press brake pedal","replyToPid":0}
发表于 2023-5-22 00:23:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"yup its called slow down and enjoy the ride, there's no need to hurry up and get thru life 👍","replyToPid":0}
发表于 2023-5-15 08:29:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not everyone drives ragged out freightliner junk like you","replyToPid":474484}
发表于 2023-5-17 11:49:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your referring to the app it’s in the sound settings when you start your load","replyToPid":0}
发表于 2023-5-15 14:09:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I know what you mean. It’s annoying as hell getting on and off the ramps. Especially when you have 1/4 mile to go before you need to slow down. I haven’t found a way to shut it off either. ","replyToPid":0}
发表于 2023-5-15 10:59:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do anyone know what the warning sign that means that has 65’ in it ","replyToPid":0}
发表于 2023-5-16 23:01:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I ask the mecanician where I work! They put on 74mph","replyToPid":0}
发表于 2023-5-16 23:00:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garage do","replyToPid":0}
GMT+8, 2026-4-17 08:58 , Processed in 0.125119 second(s), 24 queries .
