查看: 57|回复: 3
microwave quit working
 楼主| 发表于 2023-5-9 09:01:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"my boyfriends microwave quit working. everything else seems to be working fine. we tried to push the rest button on the fuse box but it wont trip it is stuck. any suggestions would be appreciated thank you","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-5-9 10:42:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"If the circuit breaker won't reset there's 2 possibilities.\n1. There's a short in the microwave.\n2. The circuit breaker is broken.\n\nIf you can unplug the microwave see if the breaker will reset. If it resets with the microwave unplugged the microwave is the problem. If it won't reset with the microwave unplugged then the circuit breaker is shot.","replyToPid":0}
 楼主| 发表于 2023-5-9 09:03:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"i believe he drives a 2021 cascadia","replyToPid":0}
 楼主| 发表于 2023-5-10 23:45:10 来自手机 | 显示全部楼层
665190 发表于 2023-05-09 02:42:14 If the circuit breaker won't reset there's 2 possibilities.\n1. There's a short in the microwave.\n2. The circuit breaker is broken.\n\nIf you can unplug the microwave see if the breaker will reset. If it resets with the microwave unplugged the microwave is the problem. If it won't reset with the microwave unplugged then the circuit breaker is shot.
","text":"thank you","replyToPid":474335}
GMT+8, 2026-4-17 06:36 , Processed in 0.068560 second(s), 25 queries .
