查看: 32|回复: 20
Does Uber mess up HOS?
 楼主| 发表于 2023-4-29 13:41:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"If I were home for an extended period and I did Uber would that cause a legal issue? I’m curious because I have over a week off coming up with multiple appointments that are a nuisance but not unfit for work. Mostly catching up some dental. I like Uber. It’s fun. Probably pays better right now at $25 an hour in my area. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-5-1 06:29:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any work done outside of driving a truck must be logged as, on duty, not driving, and counted against your 70. Regardless of it being a driving job or working at McDonalds.  The people saying you don't have to log it have no clue what they are saying. The only exception that I am aware of are for firefighters/EMS/paramedics that work a 24 hour shift.","replyToPid":0}
回复 支持 6 反对 4
发表于 2023-5-1 00:18:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"no. Uber is a company that is NOT regulated for transporting freight. Uber is for transporting people like taxis. I your Uber vehicle weights more than 26,000 pounds then the answer would be yes.","replyToPid":0}
回复 支持 4 反对 2
发表于 2023-4-30 21:22:59 来自手机 | 显示全部楼层
2158553 发表于 2023-04-29 21:59:01 When you say “mess up,” what do you mean? Is it legal to drive 24 hours @Uber then jump in your truck and do 11 hours? Completely legal.\n\nIf dying from a road incident is your end goal, you do you, but you’re a grown as man, regulate yourself.
","text":"I think UBER driving would count as work towards the 70hr limit. Not likely to get caught but I'm pretty sure its supposed to be logged as work not driving.","replyToPid":474178}
回复 支持 2 反对 4
发表于 2023-4-30 11:27:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get out your manual and read it.   Some here obviously haven’t. ","replyToPid":0}
回复 支持 2 反对 4
发表于 2023-4-30 10:23:16 来自手机 | 显示全部楼层
","text":"Not legal, but you do you","replyToPid":474178}
回复 支持 6 反对 0
发表于 2023-4-30 05:59:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you say “mess up,” what do you mean? Is it legal to drive 24 hours @Uber then jump in your truck and do 11 hours? Completely legal.\n\nIf dying from a road incident is your end goal, you do you, but you’re a grown as man, regulate yourself.","replyToPid":0}
回复 支持 3 反对 3
发表于 2023-4-30 10:27:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"That's all local work. Also Uber is not under hos rules. You can work that as much as you want.","replyToPid":0}
回复 支持 3 反对 2
发表于 2023-4-29 21:42:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any work at all needs to be logged as on duty regardless of the type. Nobody would know unless something horrible happened and they did a lengthy investigation. ","replyToPid":0}
回复 支持 4 反对 1
发表于 2023-4-29 15:52:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"It counts as work towards that 70 and you have to let your company know days and hours.   Most companies aren’t ok with it. ","replyToPid":0}
回复 支持 4 反对 1
发表于 2023-5-5 23:56:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's not a dumb question. Any work that a driver is compensated for, even if it is not driving or a second job, counts against our  hours of service, and is supposed to be logged. Chances are a driver would never get caught if they did not report it, but to me it's not worth the risk.  If you get in a wreck with serious injuries, lawyers come out of the woodwork and go over the driver's life with a microscope.","replyToPid":0}
发表于 2023-4-29 20:07:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"You drive enough find other ways to make extra $ income","replyToPid":0}
GMT+8, 2026-2-5 22:58 , Processed in 0.090964 second(s), 24 queries .
