查看: 77|回复: 6
Low Clearances
 楼主| 发表于 2023-4-17 18:20:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do we avoid low clearances on the Trucker Path app?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-4-17 19:39:15 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You have to go into settings and set the specifications for your truck, i.e., height, weight, axles, etc. then it does it automatically. Still, never trust a gps 100%. Read signs, especially in North East, like New Jersey. In NJ gps can lead you to truck restricted spots on state roads"}
回复 支持 8 反对 0
发表于 2023-4-18 06:56:47 来自手机 | 显示全部楼层
916299 发表于 2023-04-17 13:52:19 it tried to take me under a 13-5 in Louisville due to the SB bypass from the east to 65S was closed. i figured that one was an honest mistake.
","text":"Lower your bags you'll fit fine. Lol","replyToPid":473950}
发表于 2023-4-18 07:16:15 来自手机
{"replyTo":"","text":"Stewpid advice to give someone","replyToPid":0}
支持 1 反对 1
发表于 2023-4-18 06:52:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Compare gps route to your atlas. Never trust a gps 100%","replyToPid":0}
发表于 2023-4-17 21:52:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"it tried to take me under a 13-5 in Louisville due to the SB bypass from the east to 65S was closed. i figured that one was an honest mistake.  ","replyToPid":0}
发表于 2023-4-22 06:34:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy and then start using an actual Truck GPS.","replyToPid":0}
发表于 2023-4-27 04:06:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I never ran into issues with trucker patch on low clearance! so far so good with trucker path with me!","replyToPid":0}
GMT+8, 2026-4-15 15:37 , Processed in 0.082206 second(s), 25 queries .
