查看: 106|回复: 6
Scales
 楼主| 发表于 2023-4-17 08:52:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m new to trucking, if I’m empty do I have to take my truck/trailer on the scale or do I drive beside it ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-4-17 13:45:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"If the weigh station has a dedicated empty lane you can use it if empty. Otherwise you drive over the scale. But, you have to enter the weigh station even when empty.","replyToPid":0}
回复 支持 9 反对 0
发表于 2023-4-19 21:49:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I always go through because if they see me sliding past it with a closed trailer my thought is that might trigger an unwanted roadside inspection.  ","replyToPid":0}
发表于 2023-4-22 06:30:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"wow. you really are new.","replyToPid":0}
 楼主| 发表于 2023-4-17 15:39:45 来自手机 | 显示全部楼层
925557 发表于 2023-04-17 05:45:30 If the weigh station has a dedicated empty lane you can use it if empty. Otherwise you drive over the scale. But, you have to enter the weigh station even when empty.
","text":"Ok thank you","replyToPid":473940}
 楼主| 发表于 2023-4-17 09:29:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m empty my trailers empty","replyToPid":473934}
发表于 2023-4-17 09:09:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"What  was your load","replyToPid":0}
GMT+8, 2026-4-17 08:58 , Processed in 1.149907 second(s), 24 queries .
