查看: 74|回复: 8
Road question.
 楼主| 发表于 2023-4-16 17:50:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm new to Trucking. What does it mean if someone flashes his clearance lights? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-4-17 01:03:12 来自手机 | 显示全部楼层
1031233 发表于 2023-04-16 10:48:46 it usually means \"Thank You\"  \nif you let him in your lane or something like that... \n\nsometimes I turn my trailer lights off and on when some inconsiderate person is blinding me with their high beams ( or their out of adjusted bright lights)
","text":"If you are parked at the truck stop ir rest area,  its probs a dude lookn for something to happen in ur sleeper.  So be careful lol.   Otherwise generally blinked clearance lights are to say “thank you” for letting me over.  ","replyToPid":473907}
回复 支持 6 反对 0
发表于 2023-4-27 04:08:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use my clearance light to thank the drivers for letting me past them! in there lane!","replyToPid":0}
发表于 2023-4-16 23:49:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Flashing clearance lights(on the front of the tractor) usually means its safe to move into their lane if you're passing.","replyToPid":0}
1万
发表于 2023-4-16 18:48:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"it usually means \"Thank You\"  \nif you let him in your lane or something like that... \n\nsometimes I turn my trailer lights off and on when some inconsiderate person is blinding me with their high beams ( or their out of adjusted bright lights)","replyToPid":0}
发表于 2023-4-27 04:07:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can move over. It's clear for you to pass in there lane!","replyToPid":0}
发表于 2023-4-29 19:58:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks","replyToPid":0}
发表于 2023-8-5 10:59:29 来自手机
{"replyTo":"","text":"Gary or ambestjunkie signaling he wants to sŭck it","replyToPid":0}
支持 1 反对 0
24
发表于 2023-6-22 09:32:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you and all clear","replyToPid":0}
发表于 2023-8-4 09:12:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s a better option to use to allow someone over rather than blinding them with your brights. Also to say thank you for providing space to move over. ","replyToPid":0}
GMT+8, 2026-4-15 15:31 , Processed in 0.119631 second(s), 24 queries .
