查看: 30|回复: 6
Trucking
 楼主| 发表于 2023-4-13 02:16:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"Make truck driving great again 🇺🇸","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-4-15 15:40:23 来自手机 | 显示全部楼层
1248444 发表于 2023-04-13 22:24:01 companies are forced to use them because of wreckless drivers that don't have them, get your head out of the ground and look at the bigger picture of the reasoning for it
","text":"The main reason they use them is to cut fuel costs. Slower a truck goes, the less fuel it uses and has a higher MPG. Second reason is that it reduces tire wear.","replyToPid":473871}
发表于 2023-4-13 09:43:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Stop outbidding each other to take cheap freight, driving prices further down. And also protest speed limiters. That’ll be a start","replyToPid":0}
发表于 2023-4-13 08:28:20 来自手机
{"replyToPid":0,"replyTo":"","text":"You’ll die trying, you’re 10-15 years tooooooo late. Way toooo many flip flops around "}
支持 3 反对 0
68
发表于 2023-4-15 18:05:09 来自手机 | 显示全部楼层
925557 发表于 2023-04-15 07:40:23 The main reason they use them is to cut fuel costs. Slower a truck goes, the less fuel it uses and has a higher MPG. Second reason is that it reduces tire wear.
","text":"People don’t like the truth, very well said & true","replyToPid":473892}
发表于 2023-4-14 06:24:01 来自手机 | 显示全部楼层
1068068 发表于 2023-04-13 01:43:14 Stop outbidding each other to take cheap freight, driving prices further down. And also protest speed limiters. That’ll be a start
","text":"companies are forced to use them because of wreckless drivers that don't have them, get your head out of the ground and look at the bigger picture of the reasoning for it","replyToPid":473848}
发表于 2023-4-17 06:44:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Im jumping on the limiter bandwagon. yall need to slow down. i still drive 55. GFYM. ","replyToPid":0}
GMT+8, 2026-2-6 02:10 , Processed in 0.104333 second(s), 24 queries .
