查看: 60|回复: 5
Follow permit routes
 楼主| 发表于 2023-4-5 09:07:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"As i new to permits for over size load , can anyone let me know how i can follow the routes given by every states. I dont have experience finding the route by atlas. Is there any app i can use ? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-4-5 09:24:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Each state lists routes to follow on permit. It's not hard. Make sure you read permits thoroughly and sign permits that require signature.  There is no app for oversize.","replyToPid":0}
发表于 2023-4-5 09:26:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also make sure you have proper flags and signs as required.  Strobe lights are also a requirement","replyToPid":0}
发表于 2023-4-7 09:14:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use Google Maps to create a turn by turn route and then send the route to my phone so I do have to be looking at paper while driving WITH AN OVERSIZED LOAD !","replyToPid":0}
发表于 2023-4-5 09:56:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also note if there are any restrictions on the times during the day you can drive. It will list them in the permits.","replyToPid":0}
发表于 2023-4-9 23:50:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"do tell forget to check your trip for construction","replyToPid":0}
GMT+8, 2026-4-17 18:14 , Processed in 0.113674 second(s), 24 queries .
