查看: 246|回复: 24
Drivers don’t forget to drain those air tanks!
 楼主| 发表于 2023-4-3 08:42:02 来自手机 | 显示全部楼层 |阅读模式
发表于 2023-4-6 06:10:40 来自手机 | 显示全部楼层
2130803 发表于 2023-04-04 17:36:50 Your obviously not a truck owner/driver. That's 101 stuff. I'm sure you can get trained in how to be real driver
","text":"Auto drain valves mooron.","replyToPid":473652}
回复 支持 2 反对 8
发表于 2023-4-6 07:43:52 来自手机 | 显示全部楼层
Use the rubber strap things that are sold in truck stop, put them around air tank lines, and hook the straps to steps. Then wait as they drain completely on their own.
{"replyToPid":473719,"replyTo":"
1068068 发表于 2023-04-05 23:22:36 Use the rubber strap things that are sold in truck stop, put them around air tank lines, and hook the straps to steps. Then wait as they drain completely on their own.
","text":"Haha rubber strap things. wow! You drive a big truck?"}
回复 支持 2 反对 8
发表于 2023-4-4 00:35:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have never had to drain my air tanks and every time i check, it’s bone dry. Don’t be fooled. ","replyToPid":0}
回复 支持 1 反对 8
发表于 2023-4-6 08:37:58 来自手机 | 显示全部楼层
2140143 发表于 2023-04-05 23:43:52 Haha rubber strap things. wow! You drive a big truck?
","text":"Don't you think helping someone is better than making fun of them? I'm sure you was rookie at some point","replyToPid":473721}
回复 支持 2 反对 2
发表于 2023-4-5 01:36:50 来自手机 | 显示全部楼层
2136099 发表于 2023-04-03 16:35:29 I have never had to drain my air tanks and every time i check, it’s bone dry. Don’t be fooled.
","text":"Your obviously not a truck owner/driver. That's 101 stuff. I'm sure you can get trained in how to be real driver","replyToPid":473632}
发表于 2023-4-3 09:35:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"How often should we drain them? For how long? ","replyToPid":0}
发表于 2023-4-5 03:30:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"water left in tanks will cause corrosion in brake system. Thus causing failure","replyToPid":473653}
发表于 2023-4-6 07:22:36 来自手机 | 显示全部楼层
842845 发表于 2023-04-04 02:24:01 How long should you drain tanks? A few seconds? A few minutes?
","text":"Use the rubber strap things that are sold in truck stop, put them around air tank lines, and hook the straps to steps. Then wait as they drain completely on their own. ","replyToPid":473645}
发表于 2023-4-4 06:52:55 来自手机 | 显示全部楼层
","text":"You drive for swift. enough said","replyToPid":473632}
发表于 2023-4-5 08:53:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"This seems to be where all the CB Rambos have come to put each other down","replyToPid":0}
发表于 2023-4-3 09:57:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"should be done everyday especially after driving through inclement weather, not including freezing temperatures","replyToPid":0}
发表于 2023-4-3 11:01:08 来自手机 | 显示全部楼层
1248444 发表于 2023-04-03 01:57:34 should be done everyday especially after driving through inclement weather, not including freezing temperatures
","text":"Exactly!","replyToPid":473626}
发表于 2023-4-4 02:48:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s why god invented air dryer that is equipped on every modern tractor. What you should’ve said was “drivers don’t forget to service your air dryer” mine is even heated.","replyToPid":0}
发表于 2023-4-4 03:00:56 来自手机 | 显示全部楼层
","text":"Where you go to driving school","replyToPid":473632}
发表于 2023-4-4 08:09:49 来自手机 | 显示全部楼层
","text":"Sounds like a rookie.","replyToPid":473632}
发表于 2023-4-4 10:24:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"How long should you drain tanks? A few seconds? A few minutes? ","replyToPid":0}
GMT+8, 2026-4-17 06:36 , Processed in 0.145185 second(s), 24 queries .
