查看: 17|回复: 6
How to trip plan as a new driver
 楼主| 发表于 2023-3-29 09:49:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do you figure out what time to take breaks and shut down for the day ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-4-1 01:39:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Like 2Truckerbabes, I also prefer to start early. Anywhere between midnight and 3am. I’ll take my break around the 6 hour mark. Then I’ll be parked for the day between noon and 3pm. \n\nI also have a dog with me on the road, so parking is a MUST every day. I park the truck at 3pm no matter what, so I know for a fact, I’ll find a spot. ","replyToPid":0}
发表于 2023-4-8 05:21:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s easy boy, you wake up, you drive. You feel hungry, sleepy, need to use the restroom, you stop. Sometimes it’s a truck stop, sometimes it’s whatever you’re around. The ground is the first toilet and still works great. Along major highways, you ain’t ever further than a mile from food and water.\n\nYou shutdown when you out of time or out of energy. If you’re late, you’re late, blame it on preplanner if you put in 8-10 hours of driving a day.","replyToPid":0}
发表于 2023-3-31 05:28:46 来自手机 | 显示全部楼层
I like to start early in the day, take my 30 at about 5 hours in, and then shut down early in the evening. Depending on where you're driving to and when your load is due will impact these factors. if you're a rookie "run a tight ship" till you get the hang of things. Once you get a couple years under your belt you will be able to relax a bit. My boss suggests running 600 miles a day which is about 9 hours. That way you don't fatigue easily. Not every company has that POV.
{"replyToPid":473489,"replyTo":"
1074972 发表于 2023-03-30 00:24:10 I like to start early in the day, take my 30 at about 5 hours in, and then shut down early in the evening. Depending on where you're driving to and when your load is due will impact these factors. if you're a rookie \"run a tight ship\" till you get the hang of things. Once you get a couple years under your belt you will be able to relax a bit. My boss suggests running 600 miles a day which is about 9 hours. That way you don't fatigue easily. Not every company has that POV.
","text":"I run 700 miles per day just so I can relax at the end, oh and I'm governed under 70mph 😁"}
发表于 2023-3-30 08:24:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"I like to start early in the day, take my 30 at about 5 hours in, and then shut down early in the evening. Depending on where you're driving to and when your load is due will impact these factors. if you're a rookie \"run a tight ship\" till you get the hang of things. Once you get a couple years under your belt you will be able to relax a bit. My boss suggests running 600 miles a day which is about 9 hours. That way you don't fatigue easily. Not every company has that POV.","replyToPid":0}
发表于 2023-3-30 21:46:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep that left door closed that simple ","replyToPid":0}
发表于 2023-3-29 21:54:22 来自手机
{"replyTo":"","text":"Bot","replyToPid":0}
支持 0 反对 1
发表于 2023-4-5 03:26:40 来自手机 | 显示全部楼层
","text":"600 miles could take 12hr atimes. It always depend on traffic /road conditions and driver battery level. If you battery (energy =alertness) is high , you can safely run 770miles per day, in 11hrs driving limit usually this would be those runs after a reset or a longer than regular 10hrs break with extra curriculums like check out of truck, exercise, play, go shopping, visit a friend etc.","replyToPid":473489}
GMT+8, 2026-2-5 22:57 , Processed in 0.132578 second(s), 24 queries .
