查看: 108|回复: 13
Suggestions on packing my things in truck?
 楼主| 发表于 2023-3-17 13:13:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"Every time I fuel up and look in the back, my things are fallen off top bunk and all the ground… I have bought bungee straps, either I’m doing it wrong or unaware of the tricks to keep it all in place… Any suggestions? Lol. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-3-17 15:07:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Use balancing beads in your tires. Check that your cab airbags are inflated, then check to make sure the leveling valve works. After that is all good, remove the top bunk mattress and you’re golden. I have everything up on the top bunk, they build it with disgusting 400lbs monster truckers in mind.","replyToPid":0}
回复 支持 3 反对 7
发表于 2023-3-18 05:07:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"get rid of the mattress and use the net","replyToPid":0}
回复 支持 2 反对 2
发表于 2023-3-17 18:09:57 来自手机 | 显示全部楼层
2119971 发表于 2023-03-17 07:07:20 Use balancing beads in your tires. Check that your cab airbags are inflated, then check to make sure the leveling valve works. After that is all good, remove the top bunk mattress and you’re golden. I have everything up on the top bunk, they build it with disgusting 400lbs monster truckers in mind.
","text":"400lbs do you ever look in mirror after you cram all those tacos in your face","replyToPid":472991}
发表于 2023-3-17 17:12:54 来自手机 | 显示全部楼层
","text":"You switch accounts again","replyToPid":472991}
发表于 2023-3-20 21:53:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hi there, I just thought I would throw in my 2 cents. What I did is I removed the mattress on the top bunk and then I bought a few “14 gallon hyper tough storage totes” from Walmart. You can arrange your things neatly inside the tote, lock the lid on and it will all stay put until you take it out. Hope it works out for you ","replyToPid":0}
发表于 2023-3-18 04:48:42 来自手机 | 显示全部楼层
","text":"Swift mechanic takes care of your truck. You don't know","replyToPid":472991}
发表于 2023-3-17 15:54:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Slow down? Haha jk","replyToPid":0}
发表于 2023-3-17 21:12:20 来自手机 | 显示全部楼层
","text":"Did you forget where you live?","replyToPid":472991}
发表于 2023-3-17 21:38:55 来自手机 | 显示全部楼层
","text":"I take a order of Tacos 🌮.","replyToPid":472991}
发表于 2023-3-18 13:22:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a basket or plastic tote to throw everything in and then Velcro it down ","replyToPid":0}
GMT+8, 2026-3-22 21:51 , Processed in 0.101549 second(s), 24 queries .
