查看: 80|回复: 4
How set up bridge heights?
 楼主| 发表于 2023-2-28 23:34:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"How set up bridge heights?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-3-1 12:38:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look at the signs ","replyToPid":0}
发表于 2023-3-1 07:02:20 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Everywhere EXCEPT New York City bridge height is the height of the bottom of the bridge from ground with maybe a half foot or so taken off as a margin of safety.\n\nNew York City, takes several feet of the real height. There are no truck routes thru New York City that a 13'6\" truck can actually use where the POSTED heights taller than the truck.\n\nKnow the height of your truck and never go under a bridge who's posted height is less than your truck(except on NYC where you're kinda 🤬ed)."}
发表于 2023-3-1 11:14:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Start by designing a bridge, get government approval for your design, get federal funding, hire a contractor, build bridge to your desired height. ","replyToPid":0}
发表于 2023-3-1 11:15:16 来自手机 | 显示全部楼层
665190 发表于 2023-02-28 23:02:20 Everywhere EXCEPT New York City bridge height is the height of the bottom of the bridge from ground with maybe a half foot or so taken off as a margin of safety.\n\nNew York City, takes several feet of the real height. There are no truck routes thru New York City that a 13'6\" truck can actually use where the POSTED heights taller than the truck.\n\nKnow the height of your truck and never go under a bridge who's posted height is less than your truck(except on NYC where you're kinda 🤬ed).
","text":"It’s actually the entire state of NY","replyToPid":472376}
GMT+8, 2026-4-17 10:26 , Processed in 0.107389 second(s), 24 queries .
