查看: 156|回复: 7
question?
 楼主| 发表于 2023-2-23 21:36:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"so my friend got into an accident  and the company ended his contract as an independent contractor. when applying to other jobs will he need to tell them of the accidnet? the company that fired him said nothing would go on his record and that when other company called to verify  he worked there they would just say he quit..","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-2-23 23:05:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well it depends on what kind of “accident” . Lots of companies will try and say braking an air line is an accident. If there was any of the following id say he needs to disclose it, a police report , injury, damage to property that would need an insurance claim. They’re just telling him that so he won’t feel bad and leave peacefully. There will be a delay in it showing up on his record. It would stink working for few weeks and then it pops up and the new company can him too for lying on his application.","replyToPid":0}
发表于 2023-2-23 22:37:21 来自手机 | 显示全部楼层
484866 发表于 2023-02-23 14:19:36 Yep.  Because it's on his DAC REPORT. If your unfamiliar.  It's basically a work history companies share to each other. If law came out. it's on CSA and State record. You can't hide that
","text":"She’s absolutely correct. What won’t go on his record is the fact he’s fired because of it but it doesn’t take a rocket scientist to figure out that’s why he’s not working with that company anymore, he quits at the same time the accident happens. They’ll know. It’s always best to be honest with everyone. If one hides anything that important then they are NOT TO BE TRUSTED. ","replyToPid":472241}
发表于 2023-2-23 22:19:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep.  Because it's on his DAC REPORT. If your unfamiliar.  It's basically a work history companies share to each other. If law came out. it's on CSA and State record. You can't hide that","replyToPid":0}
发表于 2023-2-25 19:06:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"The other company will also send it over. Don’t believe they won’t ","replyToPid":0}
 楼主| 发表于 2023-2-24 00:35:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"okay thank you for the help.  I appreciate it","replyToPid":0}
发表于 2023-2-26 11:58:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"2 months on the job and you got in an accident and fired? Go back to McDonald's.","replyToPid":0}
 楼主| 发表于 2023-2-27 00:12:14 来自手机 | 显示全部楼层
2072116 发表于 2023-02-26 03:58:29 2 months on the job and you got in an accident and fired? Go back to McDonald's.
","text":"ya he got a new job and it wasn't his fault. plus he had it all on dashcam","replyToPid":472331}
GMT+8, 2026-4-15 17:26 , Processed in 1.548397 second(s), 24 queries .
