查看: 369|回复: 12
What does “rolling across” mean?
 楼主| 发表于 2023-2-3 11:13:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does this mean that they’re letting a lot of guys through without inspection? New to the industry just learning. Thank you. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-2-3 22:49:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Means it’s open rolling you across the scale, checking weight \n\nNothing to do with the bypass. ","replyToPid":0}
回复 支持 6 反对 0
1万
发表于 2023-2-3 19:54:39 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I thought it meant driving slow across the scales... \n\"roll across\" slowly but don't stop unless the put on the red light...\n\nI thought \"by pass\" is not even going into the weigh station... hence the words \"by-pass\""}
回复 支持 6 反对 0
发表于 2023-2-3 22:36:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"they are eyeballing the truck, they have already run the license plate","replyToPid":0}
发表于 2023-2-3 13:01:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rolling across means that they are Rolling you across the scale checking  you’re  wate \nOtherwise a CB expression is checking the tension on the suspension","replyToPid":0}
发表于 2023-2-3 13:01:51 来自手机 | 显示全部楼层
1571942 发表于 2023-02-03 04:01:06 You just drive across. No inspection and no weighing. The green light stays on.
","text":"What you’re describing is bypass","replyToPid":471607}
发表于 2023-2-4 10:14:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"If they say rolling across means that thing is open find away around ","replyToPid":0}
1万
发表于 2023-2-4 16:22:30 来自手机 | 显示全部楼层
1571942 发表于 2023-02-04 08:05:12 You are correct Mr Freeze.
","text":"thanks\n 👍 🇺🇸 🙂","replyToPid":471639}
发表于 2023-2-4 16:04:38 来自手机 | 显示全部楼层
984586 发表于 2023-02-03 05:01:51 What you’re describing is bypass
","text":"That’s what it used to mean but that was before bypass but…. I’ve been red lighted in and just rolled across the scales, no weigh no inspection or was signaled to go to the left after entering the scales ramp. ","replyToPid":471613}
发表于 2023-2-4 16:05:12 来自手机 | 显示全部楼层
1031233 发表于 2023-02-03 11:54:39 I thought it meant driving slow across the scales... \n\"roll across\" slowly but don't stop unless the put on the red light...\n\nI thought \"by pass\" is not even going into the weigh station... hence the words \"by-pass\"
","text":"You are correct Mr Freeze. ","replyToPid":471615}
发表于 2023-2-3 12:01:06 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You just drive across. No inspection and no weighing. The green light stays on. "}
发表于 2023-2-4 08:51:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"There’s a lot of different options. Now who’s right????","replyToPid":0}
发表于 2023-2-4 10:14:37 来自手机 | 显示全部楼层
674413 发表于 2023-02-04 02:14:01 If they say rolling across means that thing is open find away around
","text":"Or fly on by ","replyToPid":471632}
GMT+8, 2026-4-17 10:25 , Processed in 0.131742 second(s), 24 queries .
