查看: 181|回复: 2
Do you have a spreadsheet sample with itemized expenses most use for tax reporting
 楼主| 发表于 2023-1-23 12:25:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"Do you have a spreadsheet sample with itemized expenses most use for tax reporting?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-1-23 12:32:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.irs.gov/pub/irs-pdf/f1040sc.pdf","replyToPid":0}
发表于 2023-2-2 16:26:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use quickbooks online. every reciept you scan, you create an expense and then you don't even need to keep the reciepts.\n\nit's like an advanced excel made with all the things you need.\n\nwhen you do get it, just make sure to setup chart of accounts the right way so everything falls I to proper categories","replyToPid":0}
GMT+8, 2026-4-15 12:04 , Processed in 0.112021 second(s), 24 queries .
