查看: 165|回复: 9
Info
 楼主| 发表于 2023-1-9 10:24:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"Trying to find out more about get my towing endorsement with my cdl class a what I would have to do and pay ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-1-10 07:46:26 来自手机
{"replyTo":"","text":"FNN News's wife endorses my BACOOĆK.","replyToPid":0}
支持 1 反对 3
发表于 2023-1-10 09:40:04 来自手机
{"replyToPid":470756,"replyTo":"
1980566 发表于 2023-01-09 23:46:26 This comment has been deleted
","text":"You know thats a lie. You are better known as LOVE THE GAYS!"}
支持 1 反对 2
发表于 2023-1-10 10:24:09 来自手机
","text":"Another internet troll.  With to much time on his hands."}
支持 1 反对 1
发表于 2023-1-9 13:13:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"No such endorsement needed or exists ","replyToPid":0}
发表于 2023-1-10 19:02:58 来自手机 | 显示全部楼层
","text":"I repeat myself for hearing impaired.  Verified is needed on Tp to eliminate people like you"}
 楼主| 发表于 2023-1-10 10:29:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"So I call my local dmv this morning and they said that there is a endorsement for towing and that I would need to have one if I was working for a towing company thank everyone for the help really appreciated ","replyToPid":0}
发表于 2023-1-10 02:07:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"FMCSA 383.91\n\nGuidance: For CDL purposes, the tow truck and its towed vehicle are treated the same as any other powered unit towing a non-powered unit.\n\n •    If the GCWR of the tow truck is 26,001 pounds or more and the towed vehicle alone exceeds 10,000 pounds GVWR, then the driver needs a Class A CDL.\n\n •    If the GVWR of the tow truck alone is 26,001 pounds or more, and the driver either (a) drives the tow truck without a vehicle in tow, or (b) drives the tow truck with a towed vehicle of 10,000 pounds or less GVWR, then the driver needs a Class B CDL.\n\n•     A driver of a tow truck or towing configuration that does not fit either configuration description above requires a Class C CDL only if he or she tows a vehicle required to be placarded for HM on a “subsequent move,” i.e., after the initial movement of the disabled vehicle to the nearest storage or repair facility.","replyToPid":0}
发表于 2023-1-10 02:04:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Guidance: For CDL purposes, the tow truck and its towed vehicle are treated the same as any other powered unit towing a non-powered unit.\n\n •    If the GCWR of the tow truck is 26,001 pounds or more and the towed vehicle alone exceeds 10,000 pounds GVWR, then the driver needs a Class A CDL.\n\n •    If the GVWR of the tow truck alone is 26,001 pounds or more, and the driver either (a) drives the tow truck without a vehicle in tow, or (b) drives the tow truck with a towed vehicle of 10,000 pounds or less GVWR, then the driver needs a Class B CDL.\n\n•     A driver of a tow truck or towing configuration that does not fit either configuration description above requires a Class C CDL only if he or she tows a vehicle required to be placarded for HM on a “subsequent move,” i.e., after the initial movement of the disabled vehicle to the nearest storage or repair facility.","replyToPid":0}
1万
发表于 2023-1-9 20:32:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think they have something like that in New York state... check your state's department of motor vehicles website...","replyToPid":0}
发表于 2023-1-9 22:51:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Every state is different.  But to my knowledge.  Only class A CDL is needed.","replyToPid":0}
1万
发表于 2023-1-10 20:41:48 来自手机 | 显示全部楼层
1035784 发表于 2023-01-10 02:29:40 So I call my local dmv this morning and they said that there is a endorsement for towing and that I would need to have one if I was working for a towing company thank everyone for the help really appreciated
","text":"what state do you live in ???","replyToPid":470761}
 楼主| 发表于 2023-1-10 22:35:52 来自手机 | 显示全部楼层
1031233 发表于 2023-01-10 12:41:48 what state do you live in ???
","text":"Ny ","replyToPid":470770}
GMT+8, 2026-2-6 17:09 , Processed in 0.059950 second(s), 24 queries .
