查看: 221|回复: 5
4way flashers
 楼主| 发表于 2023-1-7 23:07:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is turning in your 4 way flashers and honking the city horn before backing up no longer a thing? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-1-8 00:32:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use the air horn all the time day or night when backing up and I don't care who gets angry, but I don't just lay on it, I tug it 3 times on short short notes","replyToPid":0}
回复 支持 3 反对 2
发表于 2023-1-18 22:38:36 来自手机 | 显示全部楼层
1248444 发表于 2023-01-07 16:32:07 I use the air horn all the time day or night when backing up and I don't care who gets angry, but I don't just lay on it, I tug it 3 times on short short notes
","text":"I just back up until somebody's hood is under my tandems","replyToPid":470706}
发表于 2023-1-9 01:00:21 来自手机 | 显示全部楼层
","text":"People don’t care about the horns or flashers they will still drive behind you","replyToPid":470706}
发表于 2023-1-10 21:20:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Respectful YES, Common sense YES, Safer…certainly YES Do people do it? NO…. Some people do but a lot just don’t care sad to say ","replyToPid":0}
发表于 2023-1-9 01:09:09 来自手机
2065094 发表于 2023-01-08 17:00:21 People don’t care about the horns or flashers they will still drive behind you
","text":"ya and that's why I have a iron rod with a 4lb steel ball to beat the stupidity out of them","replyToPid":470734}
支持 1 反对 1
发表于 2023-1-7 23:42:42 来自手机
{"replyTo":"","text":"Only if you are from the continent of Africa ","replyToPid":0}
支持 1 反对 1
发表于 2023-1-19 09:00:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Definitely 4 way flashers but only a horn if there’s people walking around close to you! ","replyToPid":0}
GMT+8, 2026-2-6 05:40 , Processed in 0.082079 second(s), 24 queries .
