查看: 140|回复: 3
DEFiciecy - many truckstops in the west do not have bulk DEF right now. Top off DEF where possible.
 楼主| 发表于 2022-12-26 10:32:56 来自手机 | 显示全部楼层 |阅读模式
 楼主| 发表于 2022-12-27 09:08:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Diesel exhaust fluid - if you don't know what it is you are lucky enough to have an older truck that doesn't use it or you're a hotshot trucker that doesn't need it.","replyToPid":0}
发表于 2022-12-31 07:39:48 来自手机
{"replyTo":"","text":"Who TF are you?  I don’t work for you ","replyToPid":0}
支持 0 反对 1
发表于 2022-12-27 00:21:42 来自手机
{"replyTo":"","text":"What's a H0m0? That's you!","replyToPid":470242}
支持 0 反对 1
发表于 2022-12-26 10:51:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"what is DEF?","replyToPid":0}
发表于 2022-12-29 06:57:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looked like the pilot in tonopah AZ had ran out when i got fuel there a couple hours ago. No price on the pump and empty DEF boxes all over ","replyToPid":0}
GMT+8, 2026-2-6 05:39 , Processed in 0.096853 second(s), 24 queries .
