查看: 233|回复: 6
flatbed chains
 楼主| 发表于 2022-12-16 02:02:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"hello everyone! my question on the use of chains on flatbed:\n\nhow to tighten the chains so as not to overstrain? after all, the chains can burst, or am I wrong?\n\nps sorry if my question not have target, i’m just new boy)\n\nthanks for watching!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-12-16 03:17:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"I personally haul heavy haul. so my loads are very heavy. To answer your question.  I tighten chains as tight as I possibly can tighten. I don't want NO SLACK in chain. I also stop every couple hours to check they are still tight.","replyToPid":0}
回复 支持 8 反对 0
发表于 2022-12-16 12:12:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don't worry about cranking chains to tight. Been driving for 40 years and never had a chain break because of over tightening. Just educate yourself to what size chains you have and what their working load limit is. And whether you secure your load with chains or straps, stop every few hours and do a safety check. Check your load, check to see that your chains or straps are still tight. I've been accused of over securing but, I have never lost a load.","replyToPid":0}
回复 支持 7 反对 0
发表于 2022-12-16 08:29:35 来自手机 | 显示全部楼层
597174 发表于 2022-12-15 20:58:11 Ratchet binders are way better than snap binders
","text":"👍🗽‼️🦕🇺🇸","replyToPid":470026}
回复 支持 2 反对 2
发表于 2022-12-16 04:58:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ratchet binders are way better than snap binders ","replyToPid":0}
发表于 2022-12-16 08:29:17 来自手机 | 显示全部楼层
484866 发表于 2022-12-15 19:17:14 I personally haul heavy haul. so my loads are very heavy. To answer your question.  I tighten chains as tight as I possibly can tighten. I don't want NO SLACK in chain. I also stop every couple hours to check they are still tight.
","text":"👍👍👍🗽‼️🦕🇺🇸","replyToPid":470025}
发表于 2022-12-25 03:34:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"melnic3 is right. I've never had a chain fail. Regular binder and a 3 foot pipe. That load and trailer should become 1 piece. Keep your chains as short as possible.","replyToPid":0}
GMT+8, 2026-2-6 07:02 , Processed in 0.085754 second(s), 24 queries .
