查看: 139|回复: 2
I 80 donner pass
 楼主| 发表于 2022-12-6 23:49:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"Still restrictions at 0745. Some bad roads on the camera but the monitoring is on clear pavement. At least I know why Californians are thin and they have the eat bugs idea. I know I’m not feeling motivated to feed them. The last time I used chains I busted a fender and replaced two chains. So expensive. No thanks. I’ll watch ya all buzz by. I don’t bust my equipment for this mess. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-12-7 11:45:03 来自手机
{"replyToPid":0,"replyTo":"","text":"That's Prime's equipment. You don't own shite broad."}
支持 2 反对 2
发表于 2022-12-7 04:35:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Be careful man ","replyToPid":0}
发表于 2022-12-7 11:26:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"apparently your not putting on your chains correctly if your truck is getting damaged, I've had the same chains for the last 7 years and I have no problems whatsoever","replyToPid":0}
GMT+8, 2026-2-6 07:11 , Processed in 0.066143 second(s), 24 queries .
