查看: 208|回复: 4
Does anyone have a solution for the audio to play through Bluetooth rather than on the phone. Thanks.
 楼主| 发表于 2022-12-3 04:05:26 来自手机 | 显示全部楼层 |阅读模式
发表于 2022-12-3 15:09:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Turn on the Bluetooth feature on your phone, on the radio and look for Bluetooth or auxiliary, in some point your radio should see the Bluetooth of your phone, then you can pair them. Simple like that.","replyToPid":0}
 楼主| 发表于 2022-12-6 06:02:52 来自手机 | 显示全部楼层
220719 发表于 2022-12-03 07:09:27 Turn on the Bluetooth feature on your phone, on the radio and look for Bluetooth or auxiliary, in some point your radio should see the Bluetooth of your phone, then you can pair them. Simple like that.
","text":"Thanks. ","replyToPid":469661}
发表于 2022-12-6 12:42:18 来自手机 | 显示全部楼层
{"replyToPid":469729,"replyTo":"
1708920 发表于 2022-12-05 22:03:18 This comment has been deleted
","text":"I've been called worse lol lol lol"}
发表于 2022-12-6 09:14:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"freightliner press and hold the left side button beside the cd insert, it will ask if you want to enable Bluetooth, rotate the knob to enable and wait for it to clear, then press and hold again, search for the Bluetooth on your phone, match the pass code and then press the Src button, it will change to R Aux, then Bluetooth, you are good then","replyToPid":0}
GMT+8, 2026-3-22 07:01 , Processed in 0.080515 second(s), 24 queries .
