查看: 224|回复: 3
If you don't have tire chains.
 楼主| 发表于 2022-11-29 09:15:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"For god's sake  don't try and go up a mountain pass when chain restrictions are in place. All you and the other morons without chains do is, get stuck, block the highway and they have to close it down until they tow you out of the way. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-11-29 20:46:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"But the sign says chains are required when flashing. I have chains, it didn’t say I had to put them on.","replyToPid":0}
发表于 2022-11-29 23:42:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I always go barefoot when the lights are flashing I don't get stuck or end up wiping my feet","replyToPid":0}
发表于 2022-11-29 20:21:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Amen! Out west they will also fine the hell out of you for not putting chains on when required and fine you again for not having chains on the truck!","replyToPid":0}
GMT+8, 2026-2-6 07:11 , Processed in 0.066470 second(s), 24 queries .
