查看: 222|回复: 8
Trailer left turn signal
 楼主| 发表于 2022-11-29 02:44:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"Quick question:\nTrailer rear left turn signal doesn’t blink. The light is working but not blink. Both left side turn signals works great. I cleaned the connectors but still nothing.\nAny ideas?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-11-29 03:48:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s a dual filament bulb, one does the blinks one does the lighty. Swap the bulb with other side and see if your problem moved with it. If it didn’t, then you’ve got a bad wire somewhere ","replyToPid":0}
发表于 2022-11-29 20:49:28 来自手机 | 显示全部楼层
978189 发表于 2022-11-29 01:59:11 your pig tail isn't quite fitting properly in the electrical connection on your trailer. you can buy shims at a pilot or etc, but if you have something like a nose box to hook a bungee chord to, then hook one end of the bungee to the pigtail and pull it tight and wrap it to, then hook it behind the nose box, or any similar solid connection point on the trailer. it works for me 95% of the time. on the rare occasions that that fails, it's a bad fuse.
","text":"He never mentioned the other left turn signal wasn’t working, or even if he has one. If one works and not the other then it’s not the pigtail.","replyToPid":469551}
发表于 2022-11-29 09:59:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"your pig tail isn't quite fitting properly in the electrical connection on your trailer. you can buy shims at a pilot or etc, but if you have something like a nose box to hook a bungee chord to, then hook one end of the bungee to the pigtail and pull it tight and wrap it to, then hook it behind the nose box, or any similar solid connection point on the trailer. it works for me 95% of the time. on the rare occasions that that fails, it's a bad fuse.","replyToPid":0}
发表于 2022-11-29 03:12:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"buy a new whole light","replyToPid":0}
发表于 2022-11-29 03:13:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wire ","replyToPid":0}
 楼主| 发表于 2022-11-29 07:03:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I pulled out and replaced the lamp. Still nothing ","replyToPid":0}
发表于 2022-11-29 20:22:50 来自手机 | 显示全部楼层
936953 发表于 2022-11-28 19:48:17 It’s a dual filament bulb, one does the blinks one does the lighty. Swap the bulb with other side and see if your problem moved with it. If it didn’t, then you’ve got a bad wire somewhere
","text":"Good suggestion","replyToPid":469536}
发表于 2022-11-30 04:22:17 来自手机 | 显示全部楼层
936953 发表于 2022-11-29 12:49:28 He never mentioned the other left turn signal wasn’t working, or even if he has one. If one works and not the other then it’s not the pigtail.
","text":"I use a piece of paper or a match book cover folded over and inserted with the pig tail \"underneath\".\nIf it doesn't work I keep making the paper thicker  by folding it again and reincerting the pigtail. \nIn this case, all the pins aren't making proper contact....","replyToPid":469564}
GMT+8, 2026-4-19 19:13 , Processed in 0.102344 second(s), 24 queries .
