查看: 297|回复: 10
Lesson #3
 楼主| 发表于 2022-11-25 19:45:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"What is “LIGHT COMMUNICATION”? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-11-25 22:57:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"same thing with CB Radios, a truck without a CB is the same definition as a mechanic without tools, it doesn't work","replyToPid":0}
回复 支持 6 反对 0
 楼主| 发表于 2022-11-25 20:16:50 来自手机 | 显示全部楼层
891914 发表于 2022-11-25 11:50:10 I don't know if this is what you're talking about or not, but....\n\nThe Flashing Lights You DO Want to See\n\n More than two consecutive flashes from oncoming traffic means that there is another type of danger ahead and you should proceed with caution. You can also use your headlights to communicate with trucks, a common signal is for lane change clearance.
","text":"Yes, that’s exactly what I mean! Thank you. On 2 lane road double click brights for danger behind you, on and off 2 times for police are behind you. \nInterstate- on and off twice for clearance to move back over in front of you and blink your trailer lights to thank the one who signaled you back over, double bright lights is something is wrong with your rig. \nI wish drivers used these signals. It really helps. ","replyToPid":469417}
发表于 2022-11-25 19:50:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't know if this is what you're talking about or not, but....\n\nThe Flashing Lights You DO Want to See\n\n More than two consecutive flashes from oncoming traffic means that there is another type of danger ahead and you should proceed with caution. You can also use your headlights to communicate with trucks, a common signal is for lane change clearance.","replyToPid":0}
发表于 2022-11-26 01:57:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"LIGHT COMMUNICATION of course ","replyToPid":0}
发表于 2022-11-25 22:14:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use light signals all the time but the uneducated people don't understand what I am trying to say","replyToPid":0}
 楼主| 发表于 2022-11-28 19:53:17 来自手机 | 显示全部楼层
1248444 发表于 2022-11-25 14:57:38 same thing with CB Radios, a truck without a CB is the same definition as a mechanic without tools, it doesn't work
","text":"Yes, I agree completely. Those of us who have a CB should use it more often too. ","replyToPid":469427}
 楼主| 发表于 2022-11-26 13:00:12 来自手机 | 显示全部楼层
1248444 发表于 2022-11-25 14:14:37 I use light signals all the time but the uneducated people don't understand what I am trying to say
","text":"That’s why I’m on here. Hopefully some will read these. ","replyToPid":469425}
 楼主| 发表于 2022-11-26 13:00:53 来自手机 | 显示全部楼层
1009563 发表于 2022-11-25 17:57:26 LIGHT COMMUNICATION of course
","text":"😉 yeppers ","replyToPid":469432}
 楼主| 发表于 2022-11-28 19:52:04 来自手机 | 显示全部楼层
","text":"I know. I just do what needs to be done and figure they will figure it out. LOL. That’s why I’m on here too. I’m hoping new drivers will read these and learn. ","replyToPid":469425}
GMT+8, 2026-4-15 15:37 , Processed in 0.067276 second(s), 25 queries .
