查看: 306|回复: 28
navigation gps
 楼主| 发表于 2022-11-25 12:06:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm new to the trucking world and was wondering what gps people would recommend. I was thinking of picking up a Rand Mcnally TND 1050 10\". but was reading the reviews and truckers seem not to be very happy with them. any input would be helpful \nty","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-10-25 00:53:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"or you could go old-school and use a dry erase marker and write directions up in the corner of your windshield. I still do that sometimes.","replyToPid":0}
发表于 2023-9-27 14:07:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"learn how to read a map","replyToPid":0}
发表于 2022-11-28 02:27:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"whatever you get don't completely trust a gps. they will all lead you down roads you shouldn't be on. or routes that are less direct","replyToPid":0}
发表于 2023-10-20 04:22:10 来自手机 | 显示全部楼层
2082021 发表于 2023-09-20 17:49:14 Why get a GPS if your using Truckers Path? It’s all I use!
","text":"I'll tell you way, it has froze up with me when I really needed it, at least I was smart enough to WRITE the directions down after I called the place I  was going to. and it has sent me to the wrong place and even sent me down a road that wasn't made for trucks. I actually got out of my truck and walked down to see if a truck could get there. and it had a 10 ' 9  clearance","replyToPid":476956}
发表于 2022-12-27 10:38:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"your best bet is a Garmin 10\"...or even trucker path ..both are what I use ..  been trucking for about ten years","replyToPid":0}
发表于 2022-11-27 17:45:37 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I'm using this app for now. I had to go with a trainer for a week as a refresher (been out for 8 years) and he had both, and I didn't really like either of them. so I have this app that is constantly updated and my big rig atlas."}
发表于 2023-10-20 04:18:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"the BEST one I recommend\nDRIVERS ROAD ATLAS!!!  then get those others. a road Atlas will never malfunction, or freeze up or send you the wrong way","replyToPid":0}
发表于 2023-10-9 16:43:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just use your phone ","replyToPid":0}
发表于 2023-8-18 13:24:19 来自手机 | 显示全部楼层
836508 发表于 2022-12-27 02:38:03 your best bet is a Garmin 10\"...or even trucker path ..both are what I use ..  been trucking for about ten years
","text":"I’m in a coin flip between Garmin and trucker Path for GPS. What are your thoughts?","replyToPid":470288}
发表于 2022-11-26 01:30:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t buy a Rand McNally they are crap, Garmen are a lot better. ","replyToPid":0}
发表于 2022-11-25 19:05:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve always used my Garmen. It has a camera on it too. I’ve been very satisfied with it. ","replyToPid":0}
 楼主| 发表于 2022-11-25 20:05:22 来自手机 | 显示全部楼层
1571942 发表于 2022-11-25 11:05:35 I’ve always used my Garmen. It has a camera on it too. I’ve been very satisfied with it.
","text":"what model","replyToPid":469407}
发表于 2022-11-25 20:19:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"DELZ CAM ","replyToPid":469419}
发表于 2022-11-25 20:19:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"They are expensive but they last. I’ve had mine for 7 years. ","replyToPid":469419}
发表于 2022-11-27 18:39:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Who doesn’t like 10” ?","replyToPid":0}
发表于 2022-12-1 20:06:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin is good except for truck routing(which is a dammed big exception!).\n\nRand McNally can't do voice control.  It can only search for new locations and only if it has an active internet connection.  Garmin you can control everything by voice, of course it may hear Emerald City Way, Merry Olde Land of Oz when you ask for Main St. \n\nRand McNally display is a lot less intuitive and doesn't have an elevation(hills) display.\n\nI'm not sure the Rand McNally is any better at truck routing than Garmin.","replyToPid":0}
GMT+8, 2026-2-4 08:00 , Processed in 0.159595 second(s), 24 queries .
