查看: 342|回复: 9
Is this legal?
 楼主| 发表于 2022-11-24 03:56:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"Flatbed question - is this legal?  Couldn't simply hang the hook off the top of the rail.  The strap tension pulled the hook nearly off the top of the rail. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2022-11-29 23:51:07 来自手机 | 显示全部楼层
665190 发表于 2022-11-29 12:25:51 @realboy okay then what is the answer when hooking the top of the rail isn't safe?  The strap tension pulled the hook within about 1/8\" of the top of the rail.
","text":"Behind the bump rail and underneath the trailer on the main frame angle iron. \nNo strap should ever be on bump rail! Bump rail is not for holding down loads.","replyToPid":469562}
回复 支持 2 反对 3
发表于 2022-11-28 11:08:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bump rail is not for straps. How dŭmb can you be?  Does no one flatbeding understand that?","replyToPid":0}
回复 支持 2 反对 2
发表于 2022-11-24 20:44:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it is legal it shouldn’t be.  ","replyToPid":0}
发表于 2022-11-25 11:44:00 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"always hook from the inside, if it breaks, then the tension goes towards the load not the traffic, it's a Cardinal rule---chains are the same thing, it's cheaper to have the cargo hit then going thru someone's window by straps or chains, also make sure you have the proper straps and chains that fit your rub rails that doesn't leave hang over"}
发表于 2022-11-24 22:18:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"legally nothing on the outside of the rub rail. however i go through the rub rail hook facing out, up the outside and hook the rail.","replyToPid":0}
发表于 2023-2-26 21:55:25 来自手机 | 显示全部楼层
597174 发表于 2022-12-02 14:02:07 realboy Is correct, but no need to put someone down or tease them because they don’t know the rules, simply stating the correct way to secure the strap to the trailer would have been good.\nThe trailer rub rail is not a legal securement point, most flatbed trailers have a warning label on the rub rail stating this. hook the strap buckle down inside the rub rail to the bottom edge like real boy explained
","text":"Someone should add a picture of the correct way for the person asking. I’m sure that would be helpful for he/she","replyToPid":469643}
 楼主| 发表于 2022-11-29 20:25:51 来自手机 | 显示全部楼层
1691356 发表于 2022-11-28 03:08:39 Bump rail is not for straps. How dŭmb can you be?  Does no one flatbeding understand that?
","text":"@realboy okay then what is the answer when hooking the top of the rail isn't safe?  The strap tension pulled the hook within about 1/8\" of the top of the rail.","replyToPid":469519}
发表于 2022-12-2 22:02:07 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"realboy Is correct, but no need to put someone down or tease them because they don’t know the rules, simply stating the correct way to secure the strap to the trailer would have been good.\nThe trailer rub rail is not a legal securement point, most flatbed trailers have a warning label on the rub rail stating this. hook the strap buckle down inside the rub rail to the bottom edge like real boy explained "}
 楼主| 发表于 2022-11-28 02:45:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"@8cQM9 That's what I usually do and what I did initially.  When I did that the tension on the strap pulled the hook within 1/8\" of the top of the rail.\n\nSo what is the correct legal answer when going behind the rail and hooking the top of the rail isn't secure?"}
GMT+8, 2026-3-21 04:17 , Processed in 0.111842 second(s), 24 queries .
