查看: 570|回复: 20
Lesson # 2: What do you do if your brake (spelling corrected for the extreme ocd people) line freezes?
 楼主| 发表于 2022-11-21 20:17:21 来自手机 | 显示全部楼层 |阅读模式
发表于 2022-11-22 23:57:36 来自手机 | 显示全部楼层
1691356 发表于 2022-11-21 15:48:09 Giving lessons and you don't know \n the correct brake . break is when you stop for lunch.
","text":"Just someone who thinks he smarter than average bear 🐻.","replyToPid":469000}
回复 支持 2 反对 2
发表于 2022-11-21 23:48:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Giving lessons and you don't know \n the correct brake . break is when you stop for lunch.","replyToPid":0}
回复 支持 2 反对 2
发表于 2022-11-21 20:43:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unfreeze it!! 😊","replyToPid":0}
发表于 2023-1-27 00:37:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"draining your airtanks once a week will prevent that problem, also change your glad hand seals","replyToPid":0}
发表于 2023-1-21 20:22:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Air Line anti-freeze. Keep the air tanks drained to help prevent moisture from building.","replyToPid":469507}
发表于 2022-11-28 05:14:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Air line  antifreeze ","replyToPid":0}
发表于 2022-11-22 01:11:09 来自手机 | 显示全部楼层
","text":"Grammer police 🚔 on his 2nd fake  account.","replyToPid":469000}
发表于 2022-11-21 23:10:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"drive without breaks ","replyToPid":0}
 楼主| 发表于 2022-11-25 19:23:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"This industry has changed drastically! I can’t heat my can of beans up anymore on a floor heater! ","replyToPid":0}
发表于 2022-11-25 11:50:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"back in the day we just put the transmission in gear and never set any brakes, can't do that anymore with all this wasted money on technology or if the truck has settled in place without rolling neutral worked as well","replyToPid":0}
 楼主| 发表于 2022-11-21 20:46:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lol, yes, if one needs to go anywhere, lol. Good morning 🌞! ","replyToPid":468990}
发表于 2022-11-21 21:23:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"have you tried brake line antifreeze","replyToPid":0}
发表于 2022-11-21 21:38:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Warm it up","replyToPid":0}
 楼主| 发表于 2022-11-22 00:47:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"But how 🤔","replyToPid":468996}
 楼主| 发表于 2022-11-22 00:49:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lmbo. Some would. ","replyToPid":468998}
GMT+8, 2026-4-15 15:31 , Processed in 0.115857 second(s), 24 queries .
