查看: 373|回复: 9
Truck Lesson #1
 楼主| 发表于 2022-11-19 22:32:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"Should your airline to your trailer stay open or should you close it when you’re parked?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2022-11-21 20:16:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"The main reason for NOT pulling the red break is so they won’t freeze in cold weather. For those who answered correctly, thank you for your participation in this lesson. ","replyToPid":0}
发表于 2022-11-20 10:16:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Leave air supplied to your trailer. If you hear a swift driver set their trailer brakes, super glue a quarter on there gland hand seal and put it back on. They are dïcks any way and can’t park right ","replyToPid":0}
发表于 2022-11-20 07:12:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"You are still supposed to drain your air tanks to keep the lines from freezing. Kind of a lazy man’s trick. But less noisy than draining the lines. ","replyToPid":0}
发表于 2022-11-20 05:45:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Assuming when you say \"open\" you mean air supplied to the trailer(red knob in) - depends on conditions. \n\nIf it's snowy or icy ABSOLUTELY maintain air supply to the trailer! It will make it a lot less likely that your trailer brakes will freeze. No guarantee but it does load the dice in your favor. \n\nOtherwise pull the dammed red knob.","replyToPid":0}
发表于 2022-11-19 23:29:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"What do you mean by open???? ","replyToPid":0}
发表于 2022-11-21 15:40:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"all I can say is that if your brakes are frozen I'm not going to help, I have a torch but not reliable for others wrongful thinking, I never set my trailer brakes unless I'm getting loaded/unloading or dropping the trailer, but before I do that I slightly ride the brakes to melt off any snow or ice and dry out the brakes","replyToPid":0}
发表于 2022-11-21 07:58:21 来自手机
{"replyToPid":468952,"replyTo":"
1692752 发表于 2022-11-20 22:02:23 This comment has been deleted
","text":"You got anything new? one trick wanna be troll."}
支持 1 反对 0
发表于 2022-11-21 06:02:23 来自手机
1700531 发表于 2022-11-20 02:16:33 Leave air supplied to your trailer. If you hear a swift driver set their trailer brakes, super glue a quarter on there gland hand seal and put it back on. They are dïcks any way and can’t park right
","text":"I will feel it big boy! 💋💄👠🩱🌈","replyToPid":468941}
支持 0 反对 1
60
发表于 2022-11-20 05:48:45 来自手机 | 显示全部楼层
458789 发表于 2022-11-19 17:24:53 I keep mine released, if anyone messes with my airlines, I'll know.
","text":"You don't do a pre-trip?","replyToPid":468930}
发表于 2022-11-20 00:23:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"How are you going to give lessons when you do not even know the correct terminology?","replyToPid":0}
发表于 2022-11-20 01:24:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I keep mine released, if anyone messes with my airlines, I'll know.","replyToPid":0}
GMT+8, 2026-4-15 15:31 , Processed in 0.118340 second(s), 25 queries .
