查看: 263|回复: 3
PACCAR engine troubles
 楼主| 发表于 2022-11-6 10:57:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi to everyone! I have Kenworth T680 next generation. When I passed about 60 thousand miles, some unsubscribe noise have appeared from engine while running gear up. So, it’s looks like, if cylinders doesn’t gets fuel enough or something wrong with injection. Truck loosing power in the hills etc. I dropped truck in dealership, they made diagnostics and replaced one of injectors, but this noise still present?! Maybe somebody had same problem? I’m really appreciate for your opinion!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-11-7 09:11:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"get rid of it, you're gonna have nothing but continuous problems, mine was in the shop at at least once a month for issues and it was costing me time and money so I got a Cascadia and much better results, only downtime is for regular maintenance","replyToPid":0}
发表于 2022-11-7 03:23:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Paccar are junk. sell it get a cat 3406b.","replyToPid":0}
发表于 2022-11-7 12:04:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Has the oil been changed? \nSeen it where trucks put on 70,000 miles without a oil change , and damage the engine","replyToPid":0}
GMT+8, 2026-2-4 09:27 , Processed in 0.080700 second(s), 24 queries .
