查看: 313|回复: 8
Tyson in Rochelle Illinois
 楼主| 发表于 2022-11-4 22:27:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"\n","videos":"[]","link":"{}","pics":"[{\"description\":\"That is with the tandems slid all the way forward. Less one star for that.\\nEverything else\",\"height\":1920.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true,"externalShare":false}
发表于 2022-11-6 08:36:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just take the scenic route.","replyToPid":0}
回复 支持 4 反对 1
发表于 2022-11-6 08:16:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I came out of there about the same time as you. I had a super tiny load paid well until I got hit and decommissioned at flying j. ","replyToPid":0}
发表于 2022-11-24 03:50:52 来自手机 | 显示全部楼层
1248444 发表于 2022-11-09 02:05:29 that's why I double check my load before leaving the shippers and if it's not loaded correctly back in the door I go and I take photos and make them fix it or I reject it
","text":"Hard to double check when the problem is a non-visible weight issue. Unless there's a scale AT the customer and even then they may require a certified scale ticket before they'll rework a load.","replyToPid":468644}
发表于 2022-11-9 10:05:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's why I double check my load before leaving the shippers and if it's not loaded correctly back in the door I go and I take photos and make them fix it or I reject it","replyToPid":0}
发表于 2022-11-7 01:34:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"can you move your 5th wheel?","replyToPid":0}
发表于 2022-11-7 06:16:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You just need to slide you trailer tandems forward PAST your drives. 🤣\nSorry that's really badly misloaded.  That would be what - 80 pin positions forward to balance it out?"}
发表于 2022-11-9 10:56:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm still waiting on my 79,999 scale I can post....","replyToPid":0}
发表于 2022-11-25 10:05:27 来自手机 | 显示全部楼层
665190 发表于 2022-11-23 19:50:52 Hard to double check when the problem is a non-visible weight issue. Unless there's a scale AT the customer and even then they may require a certified scale ticket before they'll rework a load.
","text":"I have 2 cameras inside the trailer, 1 facing the door and 1 facing the front of the trailer, so therefore the moment I see something wrong I go inside and tell them to stop now and fix it","replyToPid":469057}
GMT+8, 2026-2-6 07:10 , Processed in 0.084734 second(s), 24 queries .
