查看: 189|回复: 8
Garmin Dezl just froze
 楼主| 发表于 2022-11-3 03:08:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m done. This is the last time. This caused me to miss an exit, again. Going to try this as an alternate. Anyone use this on a real tablet?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-11-3 11:59:00 来自手机 | 显示全部楼层
1553211 发表于 2022-11-02 21:32:29 Are you say sometimes it is not that good
","text":"I had an old garmin, it didn't have the memory to show the entire route from east coast to west.  I bought a new garmin, no problems. and update every 6 months. Also much faster calculating a route.","replyToPid":468419}
回复 支持 1 反对 3
发表于 2022-11-3 09:26:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bro u should plan ur route & try to remember ur exit numbers.  That GPS Is just a guide. Don’t be like them somolian drivers ","replyToPid":0}
发表于 2022-11-4 22:17:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"I call my Dezl gps a crackhead gps because it doesn’t know where to go anymore the routings they do now days is absolutely absurd, so I call the routes crackhead routes. ","replyToPid":0}
发表于 2022-11-3 09:15:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"reset to factory settings or do a system update, I update mine every 30 days","replyToPid":0}
发表于 2022-11-3 05:32:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you say sometimes it is not that good","replyToPid":0}
发表于 2022-11-3 03:51:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"get a new gps. garmin is good, new hardware.","replyToPid":0}
发表于 2022-11-3 10:57:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"I agree with above. Go over your route before and know your exit numbers. Depending on the area GPS may be lagging slightly that's the service to the phone/tablet. Also, it helps to make sure to listen, it gives you warnings at 2 miles, 1 mile, 3/4 mile, 1/2 mile, 1/4 mile, 500ft..... I know judging distance is an issue for some like my boyfriend","replyToPid":0}
发表于 2022-11-5 11:29:22 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Have you kept it updated? "}
GMT+8, 2026-2-6 07:10 , Processed in 0.144948 second(s), 24 queries .
