查看: 183|回复: 2
International Auto Climate
 楼主| 发表于 2022-10-30 14:05:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"I followed the directions but it doesn't work well. It only blows cold when the truck is running (I enable the auto start button when I stop at night) and I have to run the Espar for any heat at all.\n\nTurning the auto climate button off doesn't seem to do anything.\n\nCan someone explain the steps and how it works at like a third grade level? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-10-30 22:38:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also as soon as you shut the truck off (make sure in neutral)  hit the auto start button right away.  Make sure the light is on solid or it won't work properly.  If it isn't on or it flashes it isn't working properly.  Turn it off, I started the truck, ran for 5 mins, shut off and turn on asap. Hope that helps","replyToPid":0}
发表于 2022-10-30 22:12:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you have the dash and bunk controls set to heat?  Also make sure the fan controls are on as well.","replyToPid":0}
GMT+8, 2026-3-21 01:14 , Processed in 0.097104 second(s), 24 queries .
