查看: 218|回复: 6
Pushrod
 楼主| 发表于 2022-10-30 00:17:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"While doing inspection we usually don’t check pushrod stroke as it takes time. If MTO pulls up will he ask me questions like what’s chamber size , how much is reading of stroke etc. or they start doing inspection on their own and don’t ask driver anything.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-10-30 00:20:59 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Stroke?"}
发表于 2022-10-30 08:05:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"post makes no sense","replyToPid":0}
发表于 2022-10-30 10:46:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"They typically know the score and unless you have a headlight out or a huge crack in your field of vision or an obviously under inflated or very bald tire, they won't bother you. I've litterally had one working headlight, no running lights without flipping the switch on and off 20 times, until they come on and been 5k overweight and still gotten a CVSA sticker. if you don't have anything wrong with your truck that is likely to cause a real safety issue, or you are hauling hazmat with a plaquard missing, they won't bother you, but might put you through a level 2. if you're driving a straight truck you'll get a level 1 every week or so. their lazy too and are trying to keep their numbers up. When you get pulled over for an inspection, ask the officer to \"Let you know if anything he/she/wtf finds anything \"marginal\", so that you can get it fixed before it becomes a problem.This typically will result in a clean inspection and a call to your company to have a tire replaced or etc at the worst and usually a CVSA sticker and a clean level 1 inspection","replyToPid":0}
发表于 2022-10-30 22:45:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fyi, look at your truck inspection sheet, it tells you chamber size on it anyway.  Also gives you the pushrod \"stroke\" or \"measurement\".  They do ask questions, like your address, did you do a pre trip, did you pick up the load already sealed (if a van) and all kinds of other questions.  I personally have never been asked chamber size.  They have measured though.","replyToPid":0}
 楼主| 发表于 2022-10-31 01:26:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you so much guys as i am new so i am worried more.. every time i pass a scale I think i can get a ticket even though i do my pre trip well still maybe its Fear ","replyToPid":0}
发表于 2022-11-3 09:45:42 来自手机 | 显示全部楼层
1649470 发表于 2022-10-30 17:26:20 Thank you so much guys as i am new so i am worried more.. every time i pass a scale I think i can get a ticket even though i do my pre trip well still maybe its Fear
","text":"Bro you can’t live in fear like that. Just do your best to be prepared for the pigs at the weigh station but you know usually when u get a PM done at a shop u can ask them to check that pushrod measurement.  You sound like your family will miss meals if u get a citation ","replyToPid":468289}
GMT+8, 2026-4-17 18:39 , Processed in 0.103119 second(s), 24 queries .
