查看: 172|回复: 4
140 gallons to fill up from Empty?
 楼主| 发表于 2022-10-25 14:02:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm confused. If my fuel gauge says empty and I have 200 gallons worth of tank, why would it only fill to 10 gallons? whats the 60 reserve for? Will my truck use it past empty? that's a lot of unused fuel. \n\nI'm also curious if more women run out of fuel than men. in my company I have seen 2 women emergency fueling on the side of the road and just them. I ran above the fuel efficiency requirements to make my recommended stop. the last place I topped off was a terminal and I think I wasn't topped off. it was a one sided fill. I pushed and found my 60 gallon reserves. very interesting. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-10-25 21:49:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"maybe your fuel gauge is not working correctly. most fuel tanks will only allow a 95% filled leaving room for air. otherwise they would not drain properly.","replyToPid":0}
发表于 2022-10-26 06:43:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"40 gal. after empty gauge , and red light .\nunless you use diesel treatment, in your tanks, to keep them clean, you should, get fuel, before you get to this point. you don't want to pull, all that sludge and grime, up into your filters .","replyToPid":0}
发表于 2022-10-27 05:50:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I reset my odometer trip meter leg whenever I topoff both fuel tanks. On a 2020 freightliner its on the dash, left most side of 6 icons. Move the left arrow button on leftside of steering wheel to the Home icon. Press the down arrow twice to Leg. Hold the OK button to Reset the info to 0.00mi and 0.0mpg.  I do it to both my pickup and car at home too. Ive never trusted a fuel guage since I ran out of fuel once.","replyToPid":0}
发表于 2022-10-28 09:33:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Some of that might be the truck manufacturer trying to compensate for the goofy way a truck's diesel tanks fill. \n\nThe tanks are essentially a barrel laying on its side.  If the tank were standing upright it would be easy to read how much fuel is in it.  ¾ height would be ¾ fuel. Laying on its side, fuel up to ¾ths the height of the tank is MORE than ¾ths full.  It's something like ⅞ths full when the tank is filled to ¾ of its height. \n\nBy the same token when the tank is only full to ¼th its height its got LESS than a quarter tank left.\n\nThe only time the height accurately measures the volume on a truck's tank is when it's completely full, completely empty and exactly half full."}
GMT+8, 2026-2-6 08:46 , Processed in 0.069765 second(s), 24 queries .
