查看: 295|回复: 19
OTR companies
 楼主| 发表于 2022-10-21 20:56:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anyone know if Pride transport and May trucking are good companies to work for ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-10-24 13:54:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"why don't you look for a company that has been around for many years and a has a very good reputation with DOT and their customers and that doesn't leave you stranded on the road when broke down like the one who I'm with, they've been around for almost 90 years and I grew up with the family, they don't shaft you on your checks and keep you rolling yet you choose when you want to go home and get back and they don't hound you as long as you're not continually late with your deliveries although winter months is a different story, if roads are closed it's not a problem, they put safety 1st","replyToPid":0}
 楼主| 发表于 2022-10-24 19:01:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"What company you work for ","replyToPid":0}
 楼主| 发表于 2022-10-24 21:30:39 来自手机 | 显示全部楼层
842845 发表于 2022-10-24 04:04:35 Orozco, gp transco, Crete are all solid otr companies with good pay! Walmart, UPS, Fed Ex is even better!
","text":"CFI good?","replyToPid":468015}
 楼主| 发表于 2022-10-22 10:18:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"What about Martin ","replyToPid":0}
发表于 2022-10-24 12:04:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Orozco, gp transco, Crete are all solid otr companies with good pay! Walmart, UPS, Fed Ex is even better! ","replyToPid":0}
 楼主| 发表于 2022-10-23 09:09:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"What are some good OTR companies ","replyToPid":0}
发表于 2022-10-22 09:47:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I wouldn't go to pride,but may maybe","replyToPid":0}
发表于 2022-10-24 10:23:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"they both pay so little","replyToPid":0}
 楼主| 发表于 2022-10-24 10:45:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"What company would you recommend ","replyToPid":0}
GMT+8, 2026-2-6 08:46 , Processed in 0.064619 second(s), 24 queries .
