查看: 388|回复: 9
Tire hub oil
 楼主| 发表于 2022-10-21 08:17:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"How to open and check hub oil ?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":4032.0,\"name\":\"\",\"url\":\"\",\"width\":3024.0}]","canComment":true,"externalShare":false}
发表于 2022-10-21 20:36:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks like a sealed grease filled hub.  Just make sure it isn't wet/sweating, carry on.","replyToPid":0}
发表于 2022-10-23 11:02:45 来自手机 | 显示全部楼层
936953 发表于 2022-10-21 22:30:37 Hammer 🔨 definitely hammer
","text":"Yup. Or just hammer down lol","replyToPid":467975}
发表于 2022-10-22 06:30:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hammer 🔨 definitely hammer","replyToPid":0}
发表于 2022-10-24 04:08:33 来自手机
{"replyTo":"","text":"Get a blue gum to sûck  that mother off. Them tell a pörch mònkéy to replace it. ","replyToPid":0}
支持 1 反对 0
74
发表于 2022-10-25 05:00:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"I haven't done mine yet and I have 194k miles on it","replyToPid":0}
发表于 2022-10-22 09:47:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"can't sealed","replyToPid":0}
发表于 2022-10-23 17:39:58 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"okay I've never done this or had to but,  looking at it wouldn't a flat head screwdriver on the cap pop it to expose the fill port and spot to....i don't know how else to say this .. finger it?"}
发表于 2022-10-22 22:39:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to take a hammer 🔨 to it and then replace it every time you want to check it which should be about 2 times a year ","replyToPid":0}
 楼主| 发表于 2022-10-23 23:12:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks y’all","replyToPid":0}
发表于 2022-10-26 21:44:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"You need a socket to take it off. it's grease filled no need to check unless tire wear or bearing noise.","replyToPid":0}
GMT+8, 2026-4-15 20:02 , Processed in 0.184336 second(s), 25 queries .
