查看: 371|回复: 11
Check engine light
 楼主| 发表于 2022-10-14 05:56:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can we drive with check engine light on? Or i will get ticket? I am on my way can’t do anything here. Light just turned on ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-10-21 10:06:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m a mechanic, you’re all idiots telling him to keep going ","replyToPid":0}
回复 支持 1 反对 3
发表于 2022-10-16 09:37:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"black tape","replyToPid":0}
发表于 2022-10-14 08:30:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a diagnostic I can run on the dashboard to pull up the error codes. If you have that/find that you can look up the code online and see what it might be. That’s one solution. ","replyToPid":0}
发表于 2022-10-15 20:18:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"You worry too much. If there’s no smoke and it’s running fine keep going. ","replyToPid":0}
发表于 2022-10-14 06:38:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Here’s your sign 🪧 ","replyToPid":0}
发表于 2022-10-14 12:31:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've had my check engine light on for months,  been through 2 level 1 inspections. No tickets.","replyToPid":0}
发表于 2022-10-14 07:47:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I drive a different truck through the week. Check engine light is always on in at least 1 of them i just run it ","replyToPid":0}
发表于 2022-10-15 07:39:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"run it till it breaks unless you own it then it's your decision","replyToPid":0}
发表于 2022-10-15 21:39:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"my light has been on for the last 74,000 miles, I ignore it until the truck decides it's time to quit working","replyToPid":0}
发表于 2022-10-16 12:29:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"stoppp lol","replyToPid":467802}
GMT+8, 2026-4-17 17:07 , Processed in 0.173751 second(s), 24 queries .
