查看: 273|回复: 3
Brake check
 楼主| 发表于 2022-10-7 02:37:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi \nHow can we check trailer brakes are properly adjusted if there is no adjustment indicator (a pin that should be in between the two pins) on brake.?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-10-7 10:21:27 来自手机 | 显示全部楼层
88424 发表于 2022-10-06 20:48:56 There should be a 10mm bolt on the brake chamber arm that you can manually adjust. The older trailers have a 1/2 inch bolt tighten it up till the brake pads touch the drum then back it off a 1/4 to 1/2 turn.
","text":"Driver could use google too. Lmao instead of looking the roomie, even if he is.  I’d ask friend before asking on here. People will give you the wrong answer just to mess you up","replyToPid":467580}
发表于 2022-10-7 04:48:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"There should be a 10mm bolt on the brake chamber arm that you can manually adjust. The older trailers have a 1/2 inch bolt tighten it up till the brake pads touch the drum then back it off a 1/4 to 1/2 turn.","replyToPid":0}
发表于 2022-10-9 00:42:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"to properly adjust brakes, you have to release the brakes, then crawl under the truck and tighten the brakes, then release it 1/2 turn. Now when you apply the brakes, they are adjuated. most new trucks auto adjust, no more need to do it manually.","replyToPid":0}
GMT+8, 2026-4-17 19:55 , Processed in 0.106096 second(s), 24 queries .
