查看: 474|回复: 16
Inspection
 楼主| 发表于 2022-10-7 00:21:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"I was doing pre trip and found truck is not having safety triangle i asked dispatch they said you can go without it no problem. What should I do? I am new driver","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-10-7 04:55:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"You should've called your safety department and told them what dispatch said. You should always have everything in writing to save your own a$$","replyToPid":0}
回复 支持 9 反对 0
发表于 2022-10-7 07:02:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Triangles are required buy them or get issued a set.  Dispatcher lied too you. be safe","replyToPid":0}
回复 支持 7 反对 0
发表于 2022-10-7 05:25:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"gotta have triangles 🔺️. either buy your own and turn in ticket, or go to your shop and tell them to give you some.  either way get them.","replyToPid":0}
回复 支持 7 反对 0
发表于 2022-10-7 00:39:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get triangles it’s required ","replyToPid":0}
发表于 2022-10-7 00:25:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"you are out of pocket for $40, go buy triangles at truck stop because it's your ticket.","replyToPid":0}
发表于 2022-10-7 02:35:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"these company's don't care about your violations... go buy the triangles and if that money becomes a big enough issue change companies","replyToPid":0}
发表于 2022-10-8 11:19:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wow your a real cub scout. Do you have a Bic lighter also to burn?","replyToPid":0}
发表于 2022-10-8 11:19:47 来自手机 | 显示全部楼层
1248444 发表于 2022-10-08 03:16:25 I've got 2 sets of triangles, 8 LED Flares, 10 Flares that have a 2 hours of burning time,  always be prepared for the unexpected
","text":"Wow your a real cub scout. Do you have a Bic lighter also to burn?","replyToPid":467622}
发表于 2022-10-9 01:32:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"as a matter of fact yes I do, I am a smoker","replyToPid":0}
发表于 2022-10-9 08:07:57 来自手机 | 显示全部楼层
1644656 发表于 2022-10-08 03:19:47 Wow your a real cub scout. Do you have a Bic lighter also to burn?
","text":"the reason why I carry extra is due the possibility of being broke down on a blind hill on a 2 lane road, my personal vehicles have the same thing as required for a commercial vehicle per safety devices, also most drivers don't realize it but it is mandatory to carry a \"white sheet\"  in your truck along with a First Aid kit","replyToPid":467624}
发表于 2022-10-8 11:16:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've got 2 sets of triangles, 8 LED Flares, 10 Flares that have a 2 hours of burning time,  always be prepared for the unexpected","replyToPid":0}
GMT+8, 2026-4-17 18:15 , Processed in 0.137964 second(s), 24 queries .
