查看: 471|回复: 11
cracked oil well
 楼主| 发表于 2022-9-27 22:22:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"has anybody experienced this and how does something like this even happen?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2080.0,\"name\":\"\",\"url\":\"\",\"width\":1560.0}]","canComment":true,"externalShare":false}
发表于 2022-9-29 09:48:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks like plugs missing ","replyToPid":0}
发表于 2022-9-28 18:20:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've had that happen in the winter on trailers after I check the oil. They get old and brittle.","replyToPid":0}
发表于 2022-9-29 13:20:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you pull the plug out or is it just missing?","replyToPid":0}
发表于 2022-9-29 13:57:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"For starters u failed pretrip because the rubber seal is gone a major part in doing pretrip and also speeding ","replyToPid":0}
发表于 2022-9-30 08:19:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve had leaking hub seals before where the seal goes missing. They aren’t very sturdy or they can be missed during repairs or loose lugnuts. I’ve hit my hub on the curb before coming out of a tight entrance at a receiver. I dropped into a storm drain. That was weird. Who knew tires could slide into a crack like that? But it just scuffed, didn’t break. I sure was worried though. ","replyToPid":0}
发表于 2022-9-29 07:49:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Replace or have it replaced being cracked. Maybe you could pull the plug and wipe dirt away but ins÷d cracked replacement is only option.","replyToPid":0}
发表于 2022-10-7 10:46:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s not an oil well.  And it’s cheap parts. Stuff happens. Fix it. Fill it up and roll. Not hard. ","replyToPid":0}
发表于 2022-10-21 05:18:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oil Well 🤣🤣🤣🤣🤣🤣🤣🤣","replyToPid":0}
发表于 2022-10-16 11:44:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"man you should know this !!!   it's your wheel hub oil...it has a plug on the outside. you should be checking this on your Pre-Trip... it's very important that you don't run this dry of oil...bad things will happen","replyToPid":0}
发表于 2022-10-21 05:18:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ha Ha ha ha ha Ha ha ","replyToPid":0}
GMT+8, 2026-2-6 10:18 , Processed in 0.089917 second(s), 24 queries .
