查看: 256|回复: 6
Regen on a Cascadia
 楼主| 发表于 2022-9-27 03:25:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"this thing won't let me do a re-gen, error message on dash board tablets, not an instrument panel, \n\nmanual regen required engine shutdown 120 seconds \n\npush regen tab on tablet, error messag \"manual regen not allowed\"\n\nhow or what do I do to get this regen started?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-9-28 00:12:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"There are several requirements that need to be met in order to start a regen. Like brake has to be set, clutch can’t be pushed, engine must be up to temperature, to name a few.","replyToPid":0}
发表于 2022-9-27 05:31:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"youtube search","replyToPid":0}
发表于 2022-9-27 12:09:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"just drive it'll clear itself, mine does it all the time and I ignore it until the message prompted me saying near full than I run the regen","replyToPid":0}
发表于 2022-9-27 03:29:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"if it needs a regen, hold the button","replyToPid":0}
 楼主| 发表于 2022-9-27 03:51:17 来自手机 | 显示全部楼层
1631565 发表于 2022-09-26 19:29:04 if it needs a regen, hold the button
","text":"button is a \"tab\" like on your phone, I push button, message reads manual regen not allowed","replyToPid":467358}
发表于 2022-9-27 05:16:10 来自手机 | 显示全部楼层
1039894 发表于 2022-09-26 19:51:17 button is a \"tab\" like on your phone, I push button, message reads manual regen not allowed
","text":"some require engine brake switch to be off, turn cruise off too","replyToPid":467359}
GMT+8, 2026-4-15 12:04 , Processed in 0.646013 second(s), 24 queries .
