查看: 182|回复: 5
Truck with brightest headlights?
 楼主| 发表于 2022-9-22 11:30:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"I used to drive a kenworth! Great truck except the headlights were always dim! I now drive an international and the one thing I notice the most is the brighter headlights! \n\nWhich truck had the brightest headlights? International, freightliner or kenworth? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2022-9-22 19:15:16 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"depends which model of each manufacturer, just make sure they are adjusted correctly and not aimed into other drivers because it is very annoying and one other thing turn off the fog lights... 👍 🇺🇸 🙂\n\none final thought, turn your headlights off when parked, that's what parking lights are for... 🤔"}
回复 支持 6 反对 1
发表于 2022-9-23 01:23:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just add your own off road lights like the czech drivers do! (axe peteonpete) make sure they are blinding and are pointed way to high. You will see great.","replyToPid":0}
发表于 2022-9-23 20:24:27 来自手机 | 显示全部楼层
1031233 发表于 2022-09-22 11:15:16 depends which model of each manufacturer, just make sure they are adjusted correctly and not aimed into other drivers because it is very annoying and one other thing turn off the fog lights... 👍 🇺🇸 🙂\n\none final thought, turn your headlights off when parked, that's what parking lights are for... 🤔
","text":"Last thought: Matter a fact dont even use your headlights drive on blind super trucker c’mon! ","replyToPid":467266}
发表于 2022-9-22 13:00:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"it mostly varies from the shade of the pavement, they all have good lighting from the factory standpoint","replyToPid":0}
发表于 2022-9-23 20:23:21 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Depends if they are adjusted right "}
GMT+8, 2026-2-6 10:19 , Processed in 0.060346 second(s), 24 queries .
