查看: 188|回复: 14
I saw a straighter shot from my PU to my DO. “Hmm.. hwy 550 from Grand Junction to Albuquerque. SWEET!” .. Holy Lord...💀
 楼主| 发表于 2022-9-21 12:01:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"Never again…some of the most terrifying and beautiful 6 hours of my life. \nDefinitely recommend driving hwy550 in a car or motorcycle, but in a semi… my steers were inches from straight drops down off the side of a mountain. No guard rails at all. Blind curves….. truly terrifying. Wow","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2022-9-21 12:26:24 来自手机 | 显示全部楼层
1248444 发表于 2022-09-21 04:14:45 I run the 550 all the time I never have any problems
","text":"I saw a flatbedder abandon his load of oranges. You may drive 550 from grand junction to Albuquerque often, but I am definitely not alone 🤣\nCrap gets REAL at Ouray, CO. Straight up, cutbacks, no guard rails, Blind corners. Oof! Crazy","replyToPid":467214}
发表于 2022-9-21 12:14:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run the 550 all the time I never have any problems","replyToPid":0}
回复 支持 2 反对 2
发表于 2022-9-21 20:22:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"That road there separate the boys from the girls you must not run back roads to much","replyToPid":0}
发表于 2022-9-21 22:52:35 来自手机 | 显示全部楼层
671341 发表于 2022-09-21 12:22:03 That road there separate the boys from the girls you must not run back roads to much
","text":"Girl here. North Dakota should be one state long guard rail. Oh you might survive no rail. You’ll die rail. Wth. ( ; ","replyToPid":467220}
发表于 2022-9-23 05:32:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have made this run one time. that was enough for me. I stayed on the wrong side of the road the whole time so you can take every corner wide. crazy route","replyToPid":0}
发表于 2022-9-24 10:09:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only have to look at the map to see is not a good truck route even if it IS a legal one. \n\nLots of hairpin and tight \"S\" curves.","replyToPid":0}
发表于 2022-9-23 08:18:07 来自手机
","text":"Oh kay big guy lol","replyToPid":467214}
支持 1 反对 0
275
发表于 2022-9-24 16:21:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I did that in Kentucky once. I was so proud I made it to the top of the mountain and the view was gorgeous but the scenic overlook had no rail and was crumbling away so I thought, maybe I better not take the pull out. most the up was crumbling with minimum guard rails. then you come over and it's a 4 lane highway again. I can't remember the route. just that I cried when it was over.","replyToPid":0}
发表于 2022-9-21 23:13:17 来自手机 | 显示全部楼层
879242 发表于 2022-09-21 14:52:35 Girl here. North Dakota should be one state long guard rail. Oh you might survive no rail. You’ll die rail. Wth. ( ;
","text":"Confused ????","replyToPid":467229}
发表于 2022-9-22 00:23:58 来自手机 | 显示全部楼层
836312 发表于 2022-09-21 04:26:24 I saw a flatbedder abandon his load of oranges. You may drive 550 from grand junction to Albuquerque often, but I am definitely not alone 🤣\nCrap gets REAL at Ouray, CO. Straight up, cutbacks, no guard rails, Blind corners. Oof! Crazy
","text":"it's just like driving up to my house very narrow steep grades no rails, 1 side is a 40ft drop off abs the otherside is a 10 ft drop off with continuous rock slides","replyToPid":467217}
 楼主| 发表于 2022-9-22 06:43:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"I literally took off my seatbelt and unlocked the door lol\nI was bailing if I needed to lol","replyToPid":0}
发表于 2022-9-22 06:51:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Those are the best routes","replyToPid":0}
GMT+8, 2026-2-5 22:58 , Processed in 0.134765 second(s), 24 queries .
