查看: 134|回复: 2
zoom settings
 楼主| 发表于 2022-9-14 08:25:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is there a way to set your zoom levels once navigating? I know how to zoom in and out at any given point, but can you change the operating zoom level so it doesn't only show you 100ft ahead of you while travelling at 80mph on a highway? Sort of like on a GPS, then it zooms in closer when you're slow in traffic or close to a turn you need to make. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-9-14 10:27:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"maybe this can help when you are navigating with 2 fingers touch the screen and you can change the point of view this will show you more road ahead good luck","replyToPid":0}
发表于 2022-9-16 09:17:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"","replyToPid":0}
GMT+8, 2026-3-22 05:19 , Processed in 0.424959 second(s), 24 queries .
