查看: 202|回复: 2
Question about a message in the pump's screen.
 楼主| 发表于 2022-9-10 09:18:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"Sometimes when I stop at some Irving truck stops, the screen of the pump have \"Dispenser reserved\" writed on it. If I try to fuel, it says I can't.\n\nWhat does this mean ? Out of fuel or closed ? Or something else ?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-9-10 10:33:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Some of the Irving’s you have to go inside to set up. Some you leave your fuel card and when done you pay inside. ","replyToPid":0}
 楼主| 发表于 2022-9-10 11:25:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for the answer.\n\nI prefer fueling somewhere else if I have to go inside.","replyToPid":0}
GMT+8, 2026-4-18 19:06 , Processed in 0.250042 second(s), 24 queries .
