查看: 520|回复: 16
personal conveyance
 楼主| 发表于 2022-9-7 00:57:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"I would not use personal conveyance for any reason. it's only a benefit to make scheduling easier for sales. it puts severe liability to the driver for almost no benefit. take the point, do your 10 hours mandatory and make your lord it over you kappa fi office people do their job. Office people need to learn to plan better. that's the job. planning. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-9-8 08:10:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use p/c , yard move , 7/3 split and 8/2 splits.  if you don't know how to use them then your not taking full advantage of the tool you've given to work with .","replyToPid":0}
回复 支持 9 反对 0
发表于 2022-9-9 09:43:45 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"When I did OTR all 48 states I used PC all the time! Did I cheat every once in a while and advance the load instead of finding the nearest place to park like you’re supposed to! Of course! Most of the time no! But there were sometimes I did! Heck you’re allowed something like 150 miles or 2 hours to find parking! I know for a fact some drivers use it to advance their load! \n\nSame with the real world in other fields! The ones getting ahead don’t always play by the rules! \n\nWith that said you’re right about planners scheduling things too tight with time sometimes! Then if you get a overtime violation the company wants to put that on you! Sometimes you just got to tell them that’s not enough time! But then guess what? They’ll find another driver who will use PC to get it done and maybe even advance the load! Which means they will be the money makers while you lose money since you play by the rules! "}
发表于 2022-9-11 08:47:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Umm, PC is for your benefit, not your company’s. If you are sitting around getting a restart and want to go eat, shop, do laundry, etc., which would you rather do, interrupt your restart or use PC, or worse yet, pay for an Uber round trip? I know which one I’m using. ","replyToPid":0}
发表于 2022-9-10 08:40:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use it off and on too. But mostly if I'm on a 34 hour reset. Sometimes to run to Wal-Mart etc.","replyToPid":0}
发表于 2022-9-12 08:36:40 来自手机 | 显示全部楼层
581829 发表于 2022-09-11 18:51:51 it's my truck nobody can tell me how or when I can drive it.
","text":"You sound like your a Supreme Court protester.","replyToPid":466954}
发表于 2022-9-9 06:10:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use every tool available to get my loads or to get myself home","replyToPid":0}
发表于 2022-9-7 01:36:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"I dont get it ","replyToPid":0}
发表于 2022-9-10 02:17:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used P.C.  I had a load going close to my family so I dropped the load and drove the truck(P.C.) 45minutes to my family and parked at a grocery store.  For the weekend. ","replyToPid":0}
发表于 2022-9-12 22:09:03 来自手机 | 显示全部楼层
466874 发表于 2022-09-09 18:45:00 I run it regularly under the COVID 19 HOS Exemption that still keeps being enacted by Congress.  \n\nI'm reefer,  haul food.  HOS Exemption.
","text":"Brother they've restricted what you're allowed to haul under that rule... Make sure what you're hauling qualifies otherwise an officer will write you a ticket longer than your arm","replyToPid":466916}
发表于 2022-9-12 02:51:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's my truck nobody can tell me how or when I can drive it.","replyToPid":0}
发表于 2022-9-7 05:27:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"post makes no sense it's all over the map off subject","replyToPid":0}
发表于 2022-9-7 11:56:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would only use PC after final drop before going home. ","replyToPid":0}
发表于 2022-9-10 02:45:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run it regularly under the COVID 19 HOS Exemption that still keeps being enacted by Congress.  \n\nI'm reefer,  haul food.  HOS Exemption.","replyToPid":0}
GMT+8, 2026-4-17 08:15 , Processed in 0.168754 second(s), 24 queries .
