查看: 145|回复: 3
Are Amazon DC deliveries strict appointments?
 楼主| 发表于 2022-9-4 16:30:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"First time delivering to a amazon warehouse wondering if they are strict about appointment times and got fines for getting there early like walmart has. Appreciate it","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-9-6 01:26:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"amazon is odd, just go in and check in with them and see what you can do. download the amazon relay app and try to find your load, (its there, even if you can't find it) armed thus, ask them to call you and see if the agent will help/fix/ change or update as may be, they are probably in India, so don't be surprised if it sounds like tech support is calling you. fines? well kinda, they will change the rate if your ratings go too low, and won't give more loads or contracts, but Communicate with Amazon and you will generally be fine. they won't give you a fine for just showing up at the gate early on my experience","replyToPid":0}
1万
发表于 2022-9-5 12:57:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't know, but you would think with all the supply chain issues that a receiver would be happy to get anything early.... 🤔","replyToPid":0}
1万
发表于 2022-9-5 13:05:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you know you are going to be early, have your dispatcher call there or you should call there and ask, tell them what you got and if they are looking for what you got maybe they will get you in... 🤔","replyToPid":0}
GMT+8, 2026-2-6 10:19 , Processed in 0.061709 second(s), 24 queries .
