查看: 382|回复: 4
KW 900 20K Update
 楼主| 发表于 2022-8-22 14:50:35 来自手机 | 显示全部楼层 |阅读模式
{"text":"Ok so what do I think of the new old school… smh… not too happy. Everything rattles like it’s a rattle can… dashboard especially.. the Nav Plus HD bs… if I could rip it out I would and replace with a full gauge package… def consumption is higher then the 2018 W9 I drove. In my opinion kenworth went down in quality. In the sleeper the black diamond vit interior panels are not properly installed and loose. Truck didn’t come with a bunk heater cause kenworth supposedly can’t get em atm. Getting about 5.5mpg on a good day and avg is about 4.7-5.0. The sound system is junk.. and I do have the premium audio thing optioned.. After about 10K miles truck started to ride like it has no suspension in the front end.. also clutch wasnt properly adjusted.. had to make em adjust correct at dealer.. right passenger stack and heat shield is no longer straight after 15K miles.. lost a rear driver side fender was single just done in… tightened it to the max and still loose .. about 1K miles ago I installed the JW Speakers all 4 cause the oem headlights just simply trash. Now my gripe with the mirrors.. must of been a Pre delivery inspection failure … when the wind hit em they moved.. had to retighten the motor mirrors.. the front wheel flaps lost those around 5k miles.. both of them they just ripped off.. i don’t how, didn’t take er into any farm fields or construction sites.. changed oil to a full synthetic at 8k after break in, did all filters minus air cleaners.. and grease.. if anyone knows how to delete this gps screen and replace with gauges let me know… so far that’s my 20-25k update on my W9. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2022-8-24 22:50:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Exactly the reason I will just keep rebuilding the older pre emissions trucks. It's not just Semi trucks, it's everything anymore! There isn't much quality or craftsmanship left in this world anymore. People used to take pride in what they did and the quality of their work but it has slipped away with each generation and isn't coming back unless we can get rid of all the bs technology and back to our kids figuring out how to have fun with 2 rocks, 5 twigs, a big stick, and a pile of dirt!","replyToPid":0}
回复 支持 7 反对 0
发表于 2022-8-23 13:25:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"That is brutal, sounds like you got a shaker not a KW.  Nothing like the 99 T800 I am in.  Like those headlights.  Definitely need a set of those","replyToPid":0}
发表于 2022-8-23 13:20:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"That is brutal, sounds like you got a shaker not a KW.","replyToPid":0}
发表于 2022-8-26 14:51:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"The last few W900s I was in rattled bad but then again they were 99s and 00s with 5+million miles so it was kinda to be expected but I gotta agree with left lane there's not much craftsmanship left anymore.","replyToPid":0}
GMT+8, 2026-2-6 10:18 , Processed in 0.069644 second(s), 24 queries .
